Gjac
Apr 22, 2021Explorer III
msta999 wrote:On mine there is just two small bolts that have to be loosened to adjust the choke to where you want it then retighten. Does yours have a bi metallic coil spring that activates the choke plate?
I did look at the generator last night and the choke linkage moves fine, looks like it is connected to a electric switch of some kind, but it is hard to get to, the housing the air filter goes in and the carb is bolted to needs to come off to see the switch. there was a cover over the linkage, that I took off and I have easy access to the choke lever, so I can start it easy from there. Anyone know here I can find a manual for this gen?
I looked around for a water heater, but no luck, not even just the tank!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
