- ItismeExplorerThis unit doesn't have a main control panel like some, nor does it have a switch in the water heater box like my last two. I didn't think about looking in the breaker box, so I'll check there just in case. I've looked all around and just haven't bumped into it yet.
- You_can_t_take_ExplorerFirst.. make sure there is water in the HWT. Then, if it is a Suburban HWT take off the outside cover. Look for a small switch inside the compartment and flip it to 'ON'. If your breaker is on you should be good to go!
- OpenRangePullenExplorershould be with the central control pane usually located in a cabnet next to the main entrance door.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
