rlw999
Feb 14, 2022Explorer
otrfun wrote:rlw999 wrote:I believe you may be confusing lifepo4 with other less stable lithium chemistries. Lifepo4 batteries are very stable and safe. They will not explode when overheated or overcharged. No significant thermal runaway issues. They also don't emit or off-gas any kind of deadly fumes like a lead cell either. Completely safe to use underneath your bed. What's not to like?
I wouldn't buy super cheap lithium batteries to put into my RV unless they were in an outside compartment far from my living area.
Lead Acid batteries don't worry me - as long as you don't short them out and you vent the hydrogen, lead acid batteries don't have a catastrophic failure mode.
Lithium batteries rely on temperature and voltage monitoring for safety - overcharging will result in catastrophic failure. The charger should prevent overcharging and will usually monitor temperature too, but the BMS inside the battery is the safety system of last resort preventing you from having a battery explosion.
Safety systems like that are the last place I want to save a few dollars, or even a few hundred dollars. I'll gladly pay for name-brand batteries if it means that I'm less likely to have the battery beneath my bed explode because my charger tried to overcharge them.
LiFePo4 batteries are *safer* than other chemistries, but still require an operational BMS to make them safe. And in some cases, the BMS in the battery itself can fail and cause a fire.
I have a huge lithionics battery under my bed, but I trust them to design a good battery and recall it if there are problems, they can't afford the bad press if there's a fire.
But if I buy a battery from some unknown reseller, the company may already be out of business (or running under another name) by the time a problem is discovered.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
