otrfun
Feb 17, 2022Explorer II
BurbMan wrote:The weak point in most of the these budget lifepo4 batteries is the BMS. Both from a capability and reliability perspective. BMS's probably fail much more often than the cells themselves.
Thoughts on this battery?
The lifepo4 battery in your link (12v 100ah) is only capable of producing 50a of continuous current. They got the price down cutting-corners with the BMS and the wiring. Even two of these cells paralleled will only provide you with 100a of continuous current. That's not enough to power a microwave or other high current device with a 2000w inverter. Two 100ah lifepo4 batteries, capable of 100a of continuous current, paralleled, would be the minimum I'd use to power a 2000w inverter.
Of course, if your power needs will remain minimal, now and in the future, then this 100ah 50a battery might be worth considering. Me, I'd pass.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
