westend
Oct 14, 2015Explorer
It sounds like you have eliminated the circuit protection by bypassing the circuit breaker and have the isolator miswired/failed. This, along with a coach battery that is depleted, would be the cause of the heat.
Yes, isolators do go bad. There is also good probability that you will never get 50A from the alternator to the coach battery through a diode isolator when everything is wired correctly.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
