Almot
Jul 14, 2014Explorer III
landyacht318 wrote:
...just because the charge controller indicates a full charge, does not mean the batteries are 100%.
If the goal is to get the solar controler to indicate a full charge, I could get there a half hour after sunrise every day, and replace batteries several times each year.
Yes, when LED indicator on controller says "full", it doesn't always tell the truth. But it - usually - tells something close to the truth. Normally, it tells that battery has hit the Bulk/Absorption setpoint and/or is now in Float mode.
Yes, Abs setpoint needs to be where battery specs require, which usually means - it needs to be adjustable. And Float setpoint needs to be adjustable too, because after some observations you might decide that for better charging you want Float different from what specs say.
Now, about controllers indicating full charge half hour after sunset :)... Maybe those were wrong controllers. Cheaper controllers keep it at Abs voltage for 60 minutes (usually), and then go to Float. Until controller indicates Float, it's not "full". Even if it doesn't show Float and only shows the beginning of Abs, getting batts to Abs half hour after sunrise would be no small feat. Only if you didn't use the battery at all after previous day charging, i.e. it was already 99% full by sunrise, then it could go into Abs shortly after sunrise. I saw this on my MPPT after had been floating new batts for a few days without loads - it went into Abs very early.
To 3 tons - yes, absolutely. 300W array can support you without a generator. You only need to be reasonable and avoid high-current devices. Doable.
