MEXICOWANDERER
Jun 16, 2016Explorer
Spec Clip Spit & Splat
Unit Weight (lbs.) 60.0000
Cooling BTU 12000
Heating BTU 14000
Volts 115V
Cooling Watts 1241
Cooling Amps (Operating) 11.3
Heating Watts 1780
Heating Amps (Operating) 16.2
Cooling Capacity (Room Enclosure Size) * Up to approximately 4,000 cu. ft. (LxWxH
Dehumidifying (pts./hr) 1.25
Thermostat Digital, Indoor Unit
Control Panel Features Mode, Fan Speed, Oscillation, Timer, Temperature
Remote Control Features Mode, Fan Speed, Oscillation, Timer, Temperature
Case Dimension (Boxed) Interior Unit: 34.5" × 16.1" × 13.9" Exterior Unit: 36.2" × 13.2" × 24.4"
Unit Dimensions Interior Unit: 31.5" × 11.0" × 7.5" Exterior Unit: 32" × 10.1" × 21.3"
Unit Weight (lbs) Interior Unit: 30.86 Exterior Unit: 70.55
Shipping Weight (lbs.) Interior Unit: 35.25 Exterior Unit: 74.96
Assembly Quick Connect Pre-Charged Hoses
Refrigerant R410a
Air Filter Yes. (cleanable, non replacement)
CFM (max) 323
Noise Interior Unit: 42 dB Exterior Unit: 53 dB
Recommended Generator Inverter, 2,000W Minimum
Warrantied Outside Temperature Range Less Than 110°F, Over 40°F (heat pump)
Recommended Use Garages, Sheds, Cabins, Tents, Greenhouses, Room Additions, Sunrooms, Apartments and Condos, Tiny H
Traditional heat pump aka Oil of Snake. Look at the stupid condensing liquid measurement. My 5,000 BTU window unit will dehumidify better than this. Impossible to cool air without removing humidity. Hissssssss Rattle Rattle
Cooling BTU 12000
Heating BTU 14000
Volts 115V
Cooling Watts 1241
Heating Watts 1780
Refrigerant R410a
CFM (max) 323
