MEXICOWANDERER
Jun 17, 2016Explorer
Gotta be careful with those numbers. My Goldstars have Freon 12. A buck/boost 1KVA emits about 30-40 watts thermal loss. A bit added on for flux emission. An integral is significantly more efficient than a split IME. I have 3 if Pianotuna's voltage correction boxes inline. The casita uses the Sola ferroresonant line-tamer. Curious the junker grade A/C units are significantly lighter in weight. Quicksilver has high Q closed cell foam insulation and Nasa grade real gold film window shading. PITA to clean without marring. The bedroom door is 1" foamboard clad in Teak. Reducing BTU gain is the hard part. That and expelling human expelled moisture.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
