Gdlow's avatar
Gdlow
101 degree heat & 30 amp air-conditioning
We are setting in a RV park where the temps today reached 102. The RV park didn't have any 50 amp sites available, so we are set on 30 amp. Had Air set on 76 degrees and current temp in MH is about 88 degrees. Turned fantastic fan on and temp rose to 90.. Do I possible have an air conditioner issue...I just had someone check everything out and said all was working ok...Do these units use Freon or as home units do?
thoughts please, and thanks
  • j-d's avatar
    j-d
    Explorer II
    Does this have the Basement A/C with Dual Compressors like I found when I looked up "Dolphin 5342" on the web? If so, I don't think it can run both on 30A service, and running on one won't cool that big a coach at 102 ambient.
  • Sounds about right. A good AC unit is generally good for a maximum 20 degree differential. To check it, use a digital thermometer directly at the AC outlet.
