icodeintx's avatar
icodeintx
10/3 Wire split
Hello friends,
I have a 10/3 wire (my 30amp service line) from the inlet to the breaker box and between the two I have a cut in the insulation. I'm wanting to splice the wire and put in a new piece from the inlet to where the cut is which is only about 3ft from the inlet. It would a major pain to replace the entire wire as one piece so I'm thinking about installing a junction box and using wire nuts to piece the wire together.
Is this a bad idea since it is the 30amp line? Will twisted wire with wire nuts hold up to those amps? My other option is a terminal connection but I don't have any experience with those. Your ideas?
Thanks in advance
Scott
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
