Gdetrailer
Feb 11, 2016Explorer III
joebedford wrote:
Couldn't find the answer to this exact question with search. My rig has a couple dozen in ceiling halogen puck fixtures like this:
We have both 4 1/2" and 3" pucks.
I bought some tower LEDs that fit the 4 1/2" pucks just fine (20W equivalent) but are too big for the 3" pucks.
They are tiny G4 halogens - bulb part is little more than 1/2" in length + another 1/2" for pins and base. Anybody have luck finding LED replacements for these tiny halogens? Brighter the better and white not yellow.
Measure the size of the REFLECTOR, that is the only way to figure out what might fit.
Your 3" pucks might be similar in reflector size to my 3" pucks which came with a 20W Halogen bulb. Mine looks like the pix below..
Measure from the socket to the edge of the reflector, mine measures 1.5" from the socket to the top of the reflector..
The LED module in the pix above measures 7/8" in diameter, it comes with extra long leads that I had to trim a bit in order to get it to fit.
That module is a 3.5W unit and gives off enough light to be a bit brighter than the 20W Halogen that was in there.
As far as I can tell, it IS the smallest G4 module that I have been able to find to date and give off the equivalent of a 20W Halogen for light.. Most are 1 1/8" in diameter or a bit larger.
You can get it here at AMAZON for a package of 6 for $25
Might be a bit brighter than what you asked for but you might like it brighter.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
