joebedford
Feb 13, 2016Nomad III
Gdetrailer wrote:Yes, that's an ultimate option but it begs the question - how does the light pattern compare to a halogen that uses the reflector?
Keep in mind, the LED module will no longer use or need the reflector, so cutting or modifying the reflector IS an option..
Also, do you think the pins are soft enough to take a bend without breaking? If I could put a couple of 45s in the pins, it would give me all the room I need?
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
