theoldwizard1
Apr 17, 2018Explorer II
First, checking the spec on Meanwell RSP procucts, you ar going to need a RSP-1500-15 to get close to 130A output ! I am pretty certain this is the largest power supply they make that still runs on 120V. It has a max power input of 17A so will a typical 120V 15A breaker hold ?
Now some good news ! The supply DOES have remote voltage sensing ! I strongly suggest that it is used. This particular power supply has remote voltage programming via a resistor across 2 of the control pins. The is a chart on page 4 of the spec sheet that shows the resistance require to go from 70% of the rated voltage (10.5V) to 100% (15V).
Can't get much easier than that.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
