MEXICOWANDERER
Apr 19, 2018Explorer
Volt drop compensation is used in long wire circuits. 10' of 2 AWG is being used in this circuit. The clamps are high spring tension copper and the jaw contacts have a shut. The highest voltage drop I can imagine is fourth column -2 max.
Having a timer precludes use of remote sensing. The unit would compensate with 16.45 volts and when the relay contacts close there would be drama.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
