full_mosey
Apr 19, 2018Explorer
time2roll wrote:full_mosey wrote:My definition is when amps start to taper below the source rating is the start of absorption. This transition will happen sooner at lower voltage.
Is the definition of transition from Bulk to ABS:
1. when the charger reaches the set-point, or
2. when the battery reaches the set-point?
HTH;
John
I think you are splitting hairs on this voltage sense issue. If you lose 1/10th volt it is not much different to care. If you are losing a full volt then you need a wire upgrade anyway. Long distance installations excepted and do not apply to this discussion of a portable charging system.
All right, you and BFL13 choose DEF 1.
In practice ,however, you strive to achieve DEF 2 by using large wiring and close proximity as a substitute Volt-sensing. You believe in DEF 2.
If you are losing a full Volt(using your example), why not let Volt-sensing take care of that?
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
