jharrell
Apr 26, 2018Explorer
Magnum also can do a "Equalizing" charge by holding down the charge button for 5 seconds where constant voltage is held for 4 hours. It defaults to 15.6V but again can be setup as high as 16V.
This equalizing mode is basically exactly what Lifeline recommends for a "conditioning" charge to be done about once a month.
Magnum seems to like Lifeline batteries as their AGM1 charge profile is specifically for Lifeline and the Equalizing charge is preset to Lifelines recommendation.
For a deep recovery procedure on a Lifeline running up to 18V and causing it to off gas I would probably want to use a manual CC power supply that can get to proper voltage and amps for such an extreme procedure.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
