Jay_Pat
Jan 11, 2019Explorer
Follow up post!
I pulled/pried the stuck switch out using a tool with a 90 degree hook on the end.
The switch cleared the housing by about 3/8". There was no more slack in the wires. Just would not come out any farther.
Impossible for me to unplug and keep connectors from falling in the hole.
I had a rv mechanic doing other stuff and had him look at it.
He took the switch with the short wires and lifted up and out. More wire came out the hole.
The switch had 90 degree connectors and I was hitting the connector/wires, pointing down inside the opening.
All I had to do was lift up on the switch and more wire would have come out. Nuts!
He lengthen the wires to reach inside the rv to the water heater cover.
I'm currently looking for a indicator light switch to install on the cover.
This will probably be my last post on this subject.
It will be nice to have an indoor 110 volt switch for the hot water heater.
Thanks, for everyone's input!!!
Pat
Pat
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
