wopachop
Jan 19, 2019Explorer
Dusty R wrote:Ive heard this joke for years but its true at times. It is a hot water heater.
HWH Hot Water Heater. How do you heat hot water?
I hear it cycle almost hourly in my trailer. There is hot water in the tank. Then the heater (gas or electric) turns on and heats the hot water even hotter. So yes, its in fact a hot water heater. This happens even if no cold water is introduced into the system.
Mine electric element seems to cycle on way to often. Same problem as others my switch got stuck.
I think my element burnt out the other day. Trailer smelled like burning electrical and water isnt hot. Heard its an easy repair but havnt looked into it yet.
Do they normally pull 11amps? Thats what started the problem. Turned off power and hooked up an amp meter because i was curious. Flipped the water heater back on and read 11amp on the meter. Went inside the trailer 30 mins later and it smelled bad.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
