Lynnmor
Jan 19, 2019Explorer II
wopachop wrote:
Do they normally pull 11amps? Thats what started the problem. Turned off power and hooked up an amp meter because i was curious. Flipped the water heater back on and read 11amp on the meter. Went inside the trailer 30 mins later and it smelled bad.
11 amps is about right so the heating element is working. There should be no odor from a failing element, so my guess is that you have a very bad connection on or near the water heater. That hot connection is a fire hazard, so find it before turning it back on. If the odor is in the water, then it is an anode or flushing issue.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
