Old-Biscuit
Oct 14, 2014Explorer III
Lighted rocker switch 'snaps' into cut-out in wall.
If you have access to rear of switch you can pinch the tabs top/bottom and push switch out
If no rear access you will need to press tabs down using thin blade tip of screw driver and pull switch out.
With switch out you can check for voltage on terminals.
Bulb is probably not replaceable as those switches are inexpensive.....just replace if bad and issue is not lack of power
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
