- pianotunaNomad IIIHi,
What make and model is the water heater? Mine has no light. - stickdogExplorerI read somewhere because of the limited capacity RV water heaters are set at a higher temp. Easy fix mix cold with the hot to get lukewarm.
- anon125ExplorerSince we cleaned out the water pipes etc the water has been very very hot, is there a reset switch?
Thanks - anon125ExplorerWe wont know if the heater works until the water has cooled.
Not keen on that option. We would probably fire up the propane waterheater.
No obvious fuse or breaker is labelled water heater.
Seems like everything else is working which is why I wanted to check the bulb
Thanks - n7bsnExplorerAll the ones I am familiar with the light is not replaceable
- 100tonExplorerAre you saying the water heater works but the light in the switch does not?
If the water heater is not working, check the 110v breaker. Turn the breaker all the way off, then back on.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
