Houston_Remodel
May 31, 2015Explorer II
You have a loose connection. Start by placing a tester in the outlet closest to the working outlet, then take apart the working outlet and check the connections. The problem is usually the outgoing hot lead from the working outlet.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
