Powerstroke2000's avatar
Mar 28, 2015
7 way trailer plug issue...
I have an '09 Ford F450, and I've got an 'ongoing' trailer brake issue. I've taken the truck to my local Ford dealer ($100.00+ to check) and said they could find no problem, but if it still doesn't work, take the truck and trailer to a trailer repair place...so, that I did. $75.00 later....after having to run the truck there, and then go again and pick it up later in the afternoon....and they tell me there is no problem. Still....no brakes coming on on the trailer with the service brakes, only if I pull the slide on the integrated brake controller. So, this same trailer repair place has another outlet in another town, which is about an additional 20 minutes further, but I thought I'd give them the benefit of the doubt...and again, hauled my truck/trailer out there. They check it all out, pull the wheels on the trailer (since it was there anyway) and checked the brakes and greased the bearings. They say all is good....but still, I'm not feeling anything when I push the brake pedal on the truck. The trailer has now sat all winter, and I'll need the trailer in a month or so....so I went out and bought a Tekonsha "trailer emulator", which you just plug in to the 7 way plug at the rear of the truck! Looked up a 'how to do' on Youtube, and sure enough, found a couple of video's on how to use the emulator correctly. When I turn the ignition key to 'on'....I should get a 12v signal light to come on...but I get 'nothing'. Left and right turn signal emulation works just fine. Brake light emulation works just fine. Putting the truck in reverse, I should get two bottom LED's to come on....I get 'nothing', albeit the bottom middle light flickers off and on about every 4 seconds.
Needless to say...I think it's a 'truck' issue now, and I'm wondering if it's the actual integrated brake controller (doesn't sound like this is an issue after researching the issue...as of yet anyway), or the 7 way plug attached to the truck?
This all makes me wonder though....why FORD and 'twice' the trailer repair shop didn't find this same issue? I'm now out about $200.00 plus.....and I had to figure out this on my own!
Anyone have any advice on if they think I should just replace the 7 way plug, or could it possibly be another electrical issue? I am having on other issues with the truck other than this. I had the integrated trailer brake controller at 8.5 (which is high) and still got no trailer brake coming on. The trailer 'lights' come on when I push the brake pedal...just no brakes coming on to slow the trailer! They 'use' to work just fine, and would even hear the odd screech of the tires if the controller was too high....but now I get nothing.
Thanks in advance!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
