BTPO1
May 31, 2015Explorer
kaydeejay wrote:Houston Remodeler wrote:I agree, but based on your observation of 110V from hot to ground, but only 8V from hot to neutral I would suspect an open neutral, maybe even as far back as the panel.
You have a loose connection.
Start there and check your connections for tightness and lack of corrosion.
X2, Quite possibly a loose neutral wire. This problem is in the 120VAC circuit and not the 12VDC circuit. JMO
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
