tenbear
Jun 01, 2015Explorer
It sounds like the outlets are built for RVs. With the power off you should be able to unsnap the back exposing the wiring. In there the copper wires are forced into the contacts. I don't remember the exact details, but with the back off you should be able to see if the contact is good.
If you can, don't put the first back in until you check the second one. It would be good to check the voltage at the second one before replacing the first, and so on down the line.
Be careful with the power on!!!
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
