bobwalter
Jun 01, 2015Explorer
It appears the problem is in the neutral wire. TURN OFF THE POWER! before the following test. Using an ohm meter, check continuity between neutral sides between receptacles. To do this, use an extension cord to extend the meter to different outlets. Check between #1 and #2, then between #2 to #3 then #3 to #4 and so on. This will indicate where the bad connection is in the series of outlets. I would guess it is somewhere between #1 (which works) and #2. Are all outlets on the same circuit breaker? If so, the bad connection is in the wire between #1 and #2. If there are more than one circuit for the outlets, the bad connection is in the load center.
Intermittent problems are the worst. Let us know what you find. Good luck
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
