rileybrake
Jun 02, 2015Explorer
tenbear wrote:rileybrake wrote:
I also have a continuity tester that I bought when I was trying to figure out 12V boat wiring. It basically looks like a small test light. Would this work to be able to isolate which receptacle has the broken wire?
I don't know enough about your continuity tester. If it depends on 12v it wouldn't work on 120v. If it functions like an ohmeter and does not require the circuit to be powered, then it would work.
I'm pretty sure it'll work. It doesn't require the power to be on in order to work. I'll shut the power off and see if I can pinpoint which outlet doesn't work.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
