qtla9111
Oct 23, 2020Nomad
MEXICOWANDERER wrote:
Dual pin bases do not utilize the socket as a polarity connection. 2-pin bases are used in vehicles where both polarities are to be run a distance. On the base the index metal pins are not staggered. Auto Parts stores commonly have rubber mats on the counter showing a master inventory of small bulbs. GE and other firms display them on the internet web sites. This will give you the correct base index which you can use for LEDs
Didn't understand a word you said. I do know that a single base bulb does not work in my particular case and I do need a dual base bulb.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
