dougrainer
Nov 23, 2017Nomad
billyboy wrote:FLY 4 FUN wrote:
I have the 12cu ft side by side with ice maker. A few things to keep in mind. Its a larger fridge than standard so it takes longer to get cold, and will use more LP when dry camping. In addition if its located in a slide it can be somewhat susceptible to temp fluctuations if vents are in the sun. This is because it vents out the side of the slide vs roof in non-slide models. There may be 1 or 2 fans in the fridge cavity to assist in circulating air...and they are often cheap and loud. One final issue I encountered during routine cleaning is I sprayed too much water on the lower vent. This put the circuit board into an "over temp limit" that I had to reset. Be cautious spraying a lot of water in/around the lower vent. Otherwise I love all the space it provides for extended trips.
How did you reset the over temp limit box?
He did not cause the Control board to "overtemp". He caused the Safety Temps box to trip. Different part. You use a magnet to reset it. Doug
