12v side seems to have shut down, recent inspection over a few days, currently hooked up to shore power and in temp storage, noted low battery on indicator board and very dim lights (LED's) and next d...
By your post it appears that the battery is not being charged. The charging line should be higher than 12.7 volts. I would check the charging system and see if it is connected and working. JMO
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 20, 2025
