joelyn
Aug 14, 2019Explorer
time2roll wrote:
Need to control the charging voltage and charging amps strictly within specs or you will kill it. Probably need a separate battery charger just for the gell battery. Lead-acid is much more forgiving.
Thanks, sounds like the gel type is not for me. I like the more forgiving ones since I do forget to charge at times, lol... thanks
Looking at this one which should do the job for me. Only use the lift a few times a year and will just keep it on a battery maintainer.
12 volt 18 amp
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
