mlts22's avatar
mlts22
Explorer II
Jun 16, 2016
12 volt buck/boost unit
For an appliance that requires four amps at 12 volts, what do I need to have it work with the 12VDC system.
The catch is that the appliance needs 12 volts. Not 12.whatever, 13.x, or 11.x depending on the SoC of the battery... but true 12.0 volt power. What is the best way to ensure an appliance gets this? Of course, I can wire in a 300 watt Morning Star SureSine inverter, then have the appliance's wall wart plug into that, which guarentees me the correct voltage... but I would be losing a good chunk of electricity via heat this way, so want to find a way to ensure 12 volts, no more, no less, is coming out.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
