tenbear
Jun 27, 2014Explorer
I would check the battery voltage right on the battery posts when trying to start the genny. If the voltage drops a way down then the battery is the problem. In that case I would check to see if the battery is being charged. If the battery voltage doesn't drop then the problem is in the wiring, most likely a bad connection.
Starting the genny takes a lot of current and it doesn't take much of a bad connection to create a problem.
Have you been doing the required battery maintenance, checking water levels and adding distilled water when required?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
