As the other responders said, yes. But, let me give you an experience based suggestion. Since you are installing 8ga charge wires to the camper, consider installing a DC-DC charger in the camper as well. You will have wires of sufficient size to support one of about 20-25 amps (I’m guessing). Your fridge will perform noticeably better in DC mode with the help of the DC-DC charger. It will maintain the battery voltage at a much higher level, and you won’t see the “death spiral” of lower voltage means more amperage means lower voltage, etc.
In milder ambient temps, with the fridge in DC mode and the thermostat set at its mid point, I’m pretty sure it’s actually cycling the DC heater, and I see the fridge temp being maintained well within the safe zone for milk, meat, etc. it’s a little harder for me to tell if it’s cycling in DC mode while driving, since I can’t see the Trimetric panel.
Look at the Renogy units, they are very price competitive now.
