burtisray wrote:
Well very for saying inverter, found manual and index pg.15 inverter/.
but then they say converter,,,, will the ground fault stop charger, I get know reading with battery disconnected,
and are there some fuse in back of convert?? plus tried to get out but wouldn't come all the way.. any secrets on pulling out..
thankyou
The link to your RV manufacturer says you have a converter/charger. A converter makes 12 volt power when your RV is plugged in or you have the generator running. The fact that it is a converter/charger means it also charges your battery. That's a normal basic installation for an RV.
You seem to be wondering if the converter is working. If your battery has a voltage above 12.8 volts, then it's being charged by your converter, and the converter is doing its basic job as a charger. If the battery voltage is below that, and you've been plugged in for a day or two, then it's either turned off or broken, or your battery is bad.
What is your battery voltage?
We'd all like to help you with your other questions about fuses, ground faults and removal, but without knowing the model and your RV design, we'd only be guessing. If you take some pictures, I'm sure someone here will recognize your converter/charger and be able to help you.
