MEXICOWANDERER
Feb 26, 2014Explorer
One bulb left on, then find ALL bulbs burned out?
A fundamental mistake is being made here. You need to check VOLTAGE across the lamp feed wires at the same time all lamps are switched on. These symptoms do not jibe.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
