JRRNeiklot
Oct 24, 2015Explorer
2oldman wrote:JRRNeiklot wrote:You're going to need a much bigger controller.. amps wise! Like an Outback 80.
If I upgrade my 500 watt solar system to 1 kw, I will need to either upgrade my solar charger or convert it to 24 volt..
I'm at 12 volts now, using a 40 amp controller. If I convert to 24 volt, the existing controller should work. Higher voltage, less amperage.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
