2oldman
Oct 24, 2015Explorer II
JRRNeiklot wrote:What will be your PV array voltage? I'm still assuming you have a 24v battery bank.
I'm at 12 volts now, using a 40 amp controller. If I convert to 24 volt, the existing controller should work. Higher voltage, less amperage.
At 1kw of panels, your 40a controller will just barely handle it.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
