time2roll
Oct 24, 2015Nomad
JRRNeiklot wrote:Lights might be able to change to 24v but the rest of the systems that need 12v will not be so easy.
If I do so, will the 12 volt lights in the trailer work?
Fridge, water heater, water pump, A/C themostat, jacks, slides, vent fans, cigar connector, antenna booster, radio, propane detector, etc. all use 12 volts.
If you go with a 24 volt main battery just get the Victron DC/DC converter posted above to feed the 12v system.
Any high draw items will need to be converted to draw 24v direct off the main battery. Such as inverters or tank heaters.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
