JRRNeiklot
Oct 24, 2015Explorer
Currently I'm running two Renogy 250 watt panels: LINK, using a Renogy Tracer 4210 40 Amp MPPT Charge Controller: LINK, and using 4 215 amp hour 6 volt batteries wired in Series/Parallel for one 12 volt 430 amp hour battery bank.
I want to get two more identical panels and double my array by moving up to 24 volt, but I'm not sure how this will effect existing 12 volt appliances. I really only run lights, water pump, and tank heaters off 12 volt. Fridge is generally ran on propane, and everything else off of an inverter. I know the basics, but I'm hardly an electrician.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
