BFL13
Oct 24, 2015Explorer II
JiminDenver wrote:
So use the converter listed above for the 12v stuff off of the 24v bank. I would think two of the panels in series paralleled with the second pair to guaranty enough voltage for a 24 volt bank. BFL tested a 24 volt panel on a 24 volt bank and there wasn't much head room to work with.
24-24 gets more amps with a buck converter controller than 24-12 even with the 60 cell panel. The issue of "overhead" arises with the 60 cell panel vs 72 cell panel.
I had no trouble getting the single 60 cell panel to raise the battery voltage to 30v, but it stalled out there. So it was able to fully charge the batteries but would not have been able to equalize them.
I can't remember if that limit was the same with MPPT and PWM. They got the same amps at 24-24, more than MPPT doing 24-12.
Salvo suggested elsewhere that you might try two 36 cell 12s in series instead of a single 60 cell 24 to beat that. (72 cell 24s are not common anymore it seems) That would not work with my older version Eco-Worthy MPPT which has a Voc limit of 42v, but it could work with the newer version that has a 50v VOC limit.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
