JRRNeiklot's avatar
JRRNeiklot
12 volt lights on a 24 volt system?
If I upgrade my 500 watt solar system to 1 kw, I will need to either upgrade my solar charger or convert it to 24 volt. I'd much rather do the latter. If I do so, will the 12 volt lights in the trailer work? If not, what must I do to change them over?
Thanks.
  • JRRNeiklot wrote:
    If I upgrade my 500 watt solar system to 1 kw, I will need to either upgrade my solar charger or convert it to 24 volt..
    You're going to need a much bigger controller.. amps wise! Like an Outback 80.
  • GENERAL COMMENT
    The ability to use much smaller, much less costly wire is a hard-to-resist siren song. 48-volts punches through marginal connections better than 12. Fifty six volts is the standard base charging voltage. But 56 volts needs respect. It pays to keep this in mind. I learned some rather sharp and abrupt lessons when I started working on paralleled Trace 5548 systems.
  • I use one of these:
    It's made by Victron, costs about $100. It's a DC/DC converter with variable output. I keep my coach at 12.5v all the time. Real nice because there's no big voltage spikes.. ever.
    24v is real nice.. I'm planning on upgrading to 48vdc.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
