  • I love seeing this stuff. The technology of lithium just went down in price.
  • should be able to parallel them
    this designed to mount 'on' (3) 18650 cells
    and those strap conductors are spot welded .. NOT soldered to the batteries
    the DIY crowd are building their own spot welders using motorcycle size batteries
    i watched some vids on youtube
    the cells could end up being expensive if you buy new
    if you buy used, you need a tester to find and grade the good ones from the bad ones
    when building packs, you want them to have matching test/grade settings
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
