Our 2013 Thor Chateau 31L Class C motorhome has two 12 volt plugs on the dash. Does anyone know if these are connected to the house batteries? Is there a simple and easy way to check besides trying to...
Usually your fuse panel for 12v is in the rear of the MH. You can run wires from the panel through your bedroom floor next to your bed and secure an outlet. Use a heaveier gage wire based on the amp draw of your device you want to run.
