wa8yxm
Mar 18, 2015Explorer III
13.6 is normal.
First: LED assemblies come in two types.. Current limited and current regulated
IF a LED is designed for a max forward current of say 20mA.. Some companies will put a current REGULATOR in series with it..Set to say 19ma.. last a long time and works well with anywhere from like 9 volts to around 30
Some put a simple current limiting resistor in the line.. and to make it brighter go a bit low on the resistance,, Leading to the current going very high, 30,40,50 mA.. and that leads to burn out.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
