wgriswold
Dec 22, 2017Explorer
time2roll wrote:gkainz wrote:And the third side says this bulb is so wasteful we need to save those resources for other items.
why is it that one category of beliefs says "I don't like that light build, so I'm not going to buy it",
while the other side of the belief system says "I don't like that light bulb, so nobody gets to buy it"?
Similar with moving from 5 gallons/flush to 1.6 gallons/flush toilet.
There just is no longer the excess resources to continue without change.
I don't have any problem with conserving water but my water saving toilet uses more water than the older models it replaced. It takes from four to seven flushes to do its job with and solid material. Everyone that visits is warned to flush early and often to avoid a plugged toilet.
I think this is a general problem. I have a gas can that spills gas in order to avoid releasing vapor and a gas fireplace that required me to buy a generator to use it as an emergency heat source in electrical outages because pilot lights were outlawed.
Things that sound good for the environment and are supposed to advance good principles are put in place without testing and often make things worse.
