noteven wrote:
Neither on board generator or a portable supplying power to the shore power connection have the same issue.
Indications are the polarity of the shore recepticle the trailer was connected to is reversed. Electrician being consulted.
Issue resolved - power supply recepticle the trailer was plugged in to had reversed polarity. Fixed.
Glad to hear it.. In reading the first I assumed you had that issue when using a Generator not shore power.
Generators ... At least portable ones, Not grounded so polarity not an issue,
But you do often have 60 volts showing on the ground wire. (no current but 60 volts. put a load on it and it hits zero and fast)
