marcsbigfoot20b
Aug 02, 2014Explorer
sch911 wrote:marcsbigfoot20b27 wrote:
Not bad.
Only problem, it has only one hose.
It will exhaust the hot air outside, but where does it suck the intake air to cool the condenser from??? It will create a vacuum in the room and suck in hot air from any crack or leak in the room.
I would go with a two hose unit.
No! IT's a hose within a hose for condenser air in/out. Yes not ideal. For inside, no vacuum in the room because it recirculates air for the evaporator airflow...
You are saying it has a fresh air intake hose INSIDE the exhaust hose??? I doubt it....they have a dual hose model that is almost exactly the same.
And yes it is for the CONDENSER cooling.
The evaporator is the part that gets cold.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 08, 2026
