BFL13's avatar
BFL13
Explorer II
Aug 09, 2018
120v Feedback from Appliance to Inverter?
Wondering if the PSW inverter can "see" what is plugged into it.
Never mind between inductive and resistive--I mean between different resistive appliances. Does each appliance have its own feedback to the inverter in some way(s) so that the inverter is "happier" with one thing plugged into it over another thing? Can the PSW inverter tell any difference?
If you have several different appliances plugged in being powered by the inverter, does that make it confusing for the inverter with different feedbacks at once? (if there are any feedbacks at all)
Does the PSW inverter need some sort of filter against these feedbacks if any? If so, what sort of filtering methods are used?
Thanks.
