BFL13
Mar 29, 2017Explorer II
DrewE wrote:BFL13 wrote:DiskDoctr wrote:
All good info ;)
My laptop power supply input is 1.5a.
2 laptops and a couple of tablets.
Thinking if I add some USB charging ports (hardwire, or is the 12v socket okay?) in a few key locations, only need to charge and run the laptops.
Maybe 750watt, or 1k?
It's about price point between them. Thoughts?
The 1000 lets you run a 120v fridge but the 750 might not, if you ever wanted to that trick while driving. (You might not want to run the fridge on gas while going down the road and you are not allowed to on a ferry, eg.)
A 750W inverter would easily run an absorption fridge on AC. A 500W one should equally well, too; the fridge heating element uses about 300W or a bit more.
For compressor fridges, the motor startup power requirements are what drive larger inverter sizes: it takes a substantial surge to get the compressor moving. For them a 1000 watt or larger inverter would indeed be necessary. Once a compressor fridge is running, it uses a lot less power than an absorption fridge, maybe 100W more or less unless defrosting. The heating element in an absorption fridge does not have any significant startup surge current requirement.
Thanks for the clarification. So if it is an absorption fridge the 750 is ok in my scenario driving down the road or on a ferry with the gas turned off.
The OP seems vague on doing the inverter "whole house" which makes the 120v lights and receptacles etc all work from the 12v batteries anyway just like being on shore power. Then just put in 120v LEDs. No rewiring beyond the inverter installation up by the batteries. In fact the 750 can have big clamps (some come that way) so you don't even need to install it.
Clamp on, plug in the shore power cable adapted down to 15a, turn off converter, put fridge and water heater on gas, and fire up the inverter. Too easy.
